C0NVERTIBLE TOP MECHANISM LUBE
Old 02-18-2008 | 05:50 PM
lar08's Avatar
Default C0NVERTIBLE TOP MECHANISM LUBE
I have an '08 Boxster. Should the Convertible Top mechanism be lubed? If yes, please recommend a lube.
Thank you
Old 02-18-2008 | 07:51 PM
dedes's Avatar
Default RE: C0NVERTIBLE TOP MECHANISM LUBE
Check out Renntech for advice or recommendations:
http://www.renntech.org/forums/index...howtopic=11833
Another thread
http://www.babblers.org/forums/showthread.php?t=9675
Old 02-20-2008 | 12:29 AM
tinchao's Avatar
ORIGINAL: dedes
Another thread
Hi, dedes, is this a comment problem or just happen in cold weather? Thanks.
Old 02-20-2008 | 01:34 AM
dedes's Avatar
ORIGINAL: tinchao
ORIGINAL: dedes
Another thread
Hello tinchao,
I really don't think this as a common problem or happening when the weather is cold. Some people notice noises on their car coming from the top and this is just some ways to solve the noise problem. Or the person that started this thread is asking if the top should be lubed and how.
quote:
Generaly all metal parts need lubrication often and the rubbers need silicone for not be destroyed from (cold -hot) deference and not listen to rubber noise during is attached on the metal body during drive .
zaphodbblbrox
02-03-2009 03:31 PM
jeffrman
01-15-2006 01:19 AM
timcantrell
03-16-2005 06:15 PM
convertguy
07-10-2004 05:30 PM
stalringt
10-23-2003 03:21 PM
