Check engine light
Old 09-10-2008 | 05:49 PM
doubleodds's Avatar
Default Check engine light
I have a 1999 Boxster and I have had a problem with a check engine light staying on and my mechanic can’t figure out the problem. The diagnostic trouble codes I’m getting are P1123 and P1125. The first thing my mechanic did was replace a vacuum hose that had a small leak; this did not fix the problem, the check engine light came back on. The second thing he did was replace a fuel hose he thought was leaking, but this did not fix the problem either, the check engine light came on again. Please help!!!
Old 09-10-2008 | 07:43 PM
dedes's Avatar
Default RE: Check engine light
check the thread below with some of my solutions toyour problem
https://www.germanautoforums.com/m_18799/tm.htm
good luck
Old 10-06-2008 | 10:17 AM
doubleodds's Avatar
Hi, thanks for your response, I'm having another issue however. My mechanic replaced the Mass Air Flow and I drove it about 50 miles and the check engine light came on again. I'm no longer getting the same codes (diagnostic trouble codes P1123 and P1125), when he tried to read it no codes showed up - he said it had re-cycled. I'm having trouble with the idle, the car is stalling out. Any suggestions as to what this might be?
Old 10-06-2008 | 05:07 PM
Sounds like there is a big intake leak. Make sure he reconnected the MAF sensor electrical connector, and that the vacuum lines to the fuel pressure regulator are attached.
ca_porsche
01-15-2006 01:10 AM
is2002
06-17-2005 07:29 PM
eneale
06-16-2005 11:22 AM
brfran
11-06-2004 09:42 AM
bjporsche
06-10-2004 10:57 PM
