engine air filter
RE: engine air filter
Access is through the top engine access cover. Open you convertible top half way, pop off the retaining cables for the top, unfasten it from the clips in the rear, fold the window section in half and forward out of the way. Close convertible top most of the way. Remove carpet by turning the 4 flip up plugs and pulling it out. Turn the 5 turn buckles on the top engine bay cover and remove. Air filter is on the drivers side in a black box. Press apart the 2 retaining clips, and slide the cover out the top. Filter will come with it.
