Engine Vibration at 3100RPM
Old 07-14-2008 | 11:06 AM
tiernp's Avatar
Default Engine Vibration at 3100RPM
I know there was a post on this a long time ago but I can't find it. I have an 01 Boxster and at aobut 3000 RPM until about 31500 RPM I have a very noticable vibration in the whole car. Its especially noticealbe when the top is up as well as when downshifitng. If I maintain speed at that 3000 RPM the vibration is constant if I accelerate through it its just for a moment. Unfortunately in 4th and 5th gears 3000 RPM is a good cruising speed. Thoughts or Ideas for me? PorscheDoc?
Old 07-15-2008 | 11:46 AM
Big Bob's Avatar
Default RE: Engine Vibration at 3100RPM
Hi Patrick, just joking first if you can achieve 31500 RPM you've got Grand Prix Technolgy + on your Boxster
I assume you are getting the vibration when you are driving from the description.
If with the car stationary and in neutral can you hold the revs at 3000-3150 andreproduce the Vibration? It may be worth exposing the engine compartment to do this check so with a block against the throttle you can set up the speed and then see if the engine shows excitation at the critical engine speed speed range.
If it is truly an Engine Vibration the engine will go into the excitation mode.
Are the times you get this vibration associated with particular road speeds too?
You may be experiencing a vibration which stems from a driveline problem rather than the Engine.
Let me know on the above questions.
Big Bob
Old 07-19-2008 | 09:12 PM
Bobiam's Avatar
I have the same symptom. Around 3000 rpm, '01 , 2.7, boxster. Only appears on occasion. Would love to know what it is before the engine explodes or something.
Bob
Old 07-21-2008 | 02:41 PM
tiernp's Avatar
Big Bob,
Sorry for the late response. I had all sorts of problems with the web sitethe day I tried to respond.
I did the stationary test and in fact the vibration was there. It was hard to hold the car in the vibration zone but I did feel it as I accelerated through the low 3000 RPMs. I have no skills when it comes to exposing the engine so I' have to get help andI have no idea what the excitation mode is... This symptom is most noticable in gears 3-4-5. Again when i accelerate through the low 3000's its only momentary but in the higher gears its very noticable. I don;t think I need a clutch but am wondering if that could be part ofthe issue. I have had this 14 months and there is 86K on the car. I have little insight to the car's history.
Old 11-26-2008 | 04:49 PM
flymymouse's Avatar
I brought this issue to the forum last year. My 02 has a vibration at around 3100 RPM and it doesn't matter if you're in gear, parked, driving or not. It's there and I don't know anything about "excitation" mode either.
Old 01-17-2009 | 10:55 PM
archer72's Avatar
Pedrosgarge
I was just researching this and found this website. If you go to DIY Projects and look under Replacing the front engine mount it will explain your problem and how to fix it. I have not tried this repair yet but will next month. Basically there saying that the front engine mount is the problem and should be replaced to fix the vibration. I hope this helps
beemah_drivah
04-12-2008 09:23 PM
flymymouse
07-07-2007 03:40 AM
Nilo Santos
01-07-2006 02:51 AM
brandnewday
05-24-2005 12:56 AM
b833
11-15-2004 07:58 PM
