tranny wont shift --automatic - help!!!!!!!!
Old 04-08-2008 | 04:57 PM
beemer2001's Avatar
Default tranny wont shift --automatic - help!!!!!!!!
was driven donw the hwy and suddenly the car felt like it was in neutral. the boxster just wont shift to but it engine runs fine. plugged into the computer and gave these codes PO-733 and PO-740. does anyone knows what could it be, how to fix it. i'm mechanic oriented, but need help with this sweet car. please porsche doctoror anyone advice.
also does anyone knows how do i check the fluid in the tranny.
thanks in advance.
Old 04-08-2008 | 08:31 PM
Default RE: tranny wont shift --automatic - help!!!!!!!!
P0733 is a Gear sel. monitor error for what I believe is 3rd gear. P0740 is a Solenoid valve torque converter clutch. I would get it to the dealer, as i believe this is going to be an extensive repair. My experience with Tiptronic repair is very limited.
Old 04-09-2008 | 01:38 AM
beemer2001's Avatar
thanks doc, also how do i check or add transmission fluid in the boxster. thanks.
Old 04-09-2008 | 03:49 PM
Well, they use a pump tool to put the fluid in the transaxle, I've never had to add any to a tip. If there hasn't been a leak, it shouldn't need any fluid.
Old 04-10-2008 | 05:15 PM
beemer2001's Avatar
if there is not fluid in the tranny, will it send all those codes? whenever the car stopped, saw lots of fluid so i think it might need some fluid, can you give any suggestions on how to remove the tranxale. thanks.
Old 04-10-2008 | 11:51 PM
You need to drop the exhaust off the car, support the engine, then you can unbolt the tranny. IIRC book time is around 10 hours to R&R the tranny.
hairless ape
06-10-2010 02:01 PM
burnssj
03-13-2009 06:47 AM
dennisfromct
05-26-2008 05:04 AM
MikeV
01-07-2008 08:45 AM
ZinFaren
03-03-2007 08:21 PM
