Wont Shift
Wont Shift
I took my boxster out one night to gas it up and I noticed it was hard to shift.. after about four city blocks I made a right turn and when I tried throwing it into second it wouldnt go in.. It persisted for awhile and there was a point where It wouldnt go into any gear even first and the car was almost to a complete stop.. I was forced to pull to the side and then throw it back into first.. ( When it wouldnt go into any gear I let go of the clutch and stepped on it again and still wouldnt go in )... after awhile It I was able to shift it but still rough.. Is this due to the cold weather?
ps. Car was shifting like butter on hot toast when I got it about 3 weeks ago
RE: Wont Shift
I live in LAand the weather got a lot cooler lately but im pretty sure it didnt go below zero... I didnt start up the car for about three or four days before this happened.. the mileage is 62k and really well taken care off.. I only warmed it up for about a minute or so because of things I have read in the forum and owners manualregarding no need for warm ups.. I took it easy though... could it be the trans fluid has not circulated in the system due to it sitting in my drive way...???
thanks for your input doc
RE: Wont Shift
You know, that sounds like a possible clutch going bad to me, especially at that mileage. I would try changing your gear oil in the transaxle first though, maybe it is old and starting to gum up a little.
RE: Wont Shift
Thanks doc.. Ill make some time next week and jack it up and check.. being a tech in IA.. what gear oil do you recommend? ill post up my findings..
by the way the engine light thing i posted up was just the MAF sensor being sensitive.. I checked the filter and something got stuck in the K&N (also the previous owner over oiled the filter). I turned off the engine light and seems to be ok now..
One other question.. When I start it up..sometimes it would sound like its choking or something.. plust the RPM would go slightly up 1k then drop to 800..normal on 986?
RE: Wont Shift
Yup, pretty normal behavior on cold start with a cold air intake. The idle is normal with any intake.
Any synthetic 75w-90 will work. We use Mobil 1 a lot, as well as swepco on occasion
MikeV
01-07-2008 08:45 AM
sp_engineering
05-12-2005 09:32 PM
