Rear door and wiper problems 04 S
Old 11-30-2010 | 11:15 AM
AdrianL's Avatar
Default Rear door and wiper problems 04 S
I've got an '04 Cayenne S and the car thinks the rear door is always open, when it isn't. The rear windshield wiper also does not work, though the rear break light does and the washer fluid nozzle functions, though I imagine the pump likely isn't there. I'm really at a loss about this one.
Old 11-30-2010 | 12:35 PM
Hm, that is an interesting one. My guess is that there is a microswitch inside the door latch assembly that isn't triggering the light to go off. I've never taken apart a rear latch assembly before though. Wiper is probably the motor or a bad connection. There should be a wiring harness connector to the rear door assembly somewhere, you might take that apart and look for corrosion in the pins which could be causing some issues.
Old 12-01-2010 | 04:31 PM
AdrianL's Avatar
I guess i've got some taking apart to do. I've also just noticed my left rear window switch only raises the window, but won't lower it? Wow electrical gremlins all at once...
Old 12-17-2010 | 05:34 AM
chris18812's Avatar
you can take it to the showrrom
rotzel
09-22-2008 11:10 PM
cgratton
02-09-2008 03:17 PM
swynn97
12-13-2007 12:16 AM
Skywalker
02-04-2007 01:13 PM
michael
03-10-2006 12:40 AM
