A serious problem! Help
Old 10-08-2008 | 04:35 PM
Teetee's Avatar
Default A serious problem! Help
Hello I have 2006 Cayenne v6!
The problem is that when I switch on heater it doesnt produce enaugh air pressure! Air is hot and I can switch it cold too but theres no pressure! Theres only a little bit blowin out of dash air vents!
Is it cabin filter?
Is it coolant?
Or something else?
Old 10-08-2008 | 09:37 PM
Lee Willis's Avatar
Default RE: A serious problem! Help
Are you sure that:
a) you are operating the control properly to force air out the vents you wants (as opposed to setting air to blow from those under the dash, at your feet)
b) that the systems making those selections are operating i.e., is air coming out anywhere? If not the fans are not working. If air is coming out somewhere but not where you set the controls then the vent valves are not working.
Old 10-09-2008 | 07:02 AM
Teetee's Avatar
Air is flowing out but with very little pressure that I hardly can feel the flow! And air is flowing there where I set! Theres no pressure!
Did you mean in first point that theres some kind of valve under the steering wheel near pedals???
jlb532
09-07-2012 05:07 AM
Teetee
12-07-2008 07:47 PM
austinbrown
07-16-2008 12:40 PM
drifting88944
12-16-2006 02:41 AM
texaskj
11-09-2003 09:38 AM
